587,427 active members*
4,669 visitors online*
    Nov 2009
    53
    Question DNC with pcmcia card
    I would like to run a large program on my 16i Mill that will not fit into memory. I have been told that you can set the I/O to 5 and use the DNC. Does this use the PCMCIA card that plugs into the slot on the left side of the screen. Is this an option I need Fanuc to turn on? Any help would be great.
    Scott(group)
    2932
    Set the I/O to 4 for the card. Instructions attached.
    Attached Files Attached Files
    Nov 2006
    9
    PCMCIA CARD CAUTION
    Be sure to leave the extension card in the cnc machine and only remove the CF card. We have had several Fanuc PCMCIA backplanes damaged. They are expensive compared to the extension cards
  1. PCMCIA card on Fanuc 18M
    By buildyourown in forum Fanuc
    Last Post: 02-23-2013, 06:56 PM
  2. Running the CNC from PCMCIA CARD
    By syamin in forum Want To Buy...Need help!
    Last Post: 10-10-2009, 06:42 PM
  3. 18i PCMCIA card question
    By TDavid in forum Fanuc
    Last Post: 11-06-2008, 12:07 PM
  4. 0i-TB and PCMCIA CARD
    By CHANDRU in forum Fanuc
    Last Post: 11-03-2008, 01:19 PM
  5. PCMCIA Card
    By bdwalker in forum Fanuc
    Last Post: 03-13-2006, 10:36 AM
