I have predator editor on the laptop at the machine
I can get the Heidenhan TNC 310 to dump to the laptop
but have been unable to upload to the control if any one has
any ideas let me know
fjd
fjd
1st make sure the settings on both the pc and the controller are correct and that your baud isn't too high. Second check the pins on the cable to make sure they're wired correctly.
Also, do a search on the forum as this has been covered a few times and you might find something in the old posts.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
What version of the editor are you running?
You say you re able to get a program in to the laptop from the control correct?
So you have checked all the settings?
Cadcam
predator 5.1
correct the down load to the laptop is great.
i do see some chacters at the end of down that i don't know
what the are .
also the begining line of down load is sting od box looking chacters.
FORD = First On Race DAy
Make sure the first chacter is a % and one at the end.
Ok this is our older editor.
Cadcam
cadcam
is there a place to set these chacter's so
that it would work every time?
thanks
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
hi fjd
the first thing you need to do is go into mod functions and look
if option is set to fe if it is that is the problem
fe protacal is the setting heidenhain use for there software ie:
tnc remo and will allow it to blockwise transfer but it allows to send files from the controller to a pc but you cannot send back
so go into mod functions
and change your setting from fe to ext1
then try again this should cure your problem
best regards
peter
Thanks peter for the reply.
As soon as lunch is over i will give it another look.
fjd
hi fjd
also if this does not work which i think it will
remember in your file you recieved from your m/c to your laptop
and you said there was funny characters at the begining and at the end cut them out and paste to program you are trying to send
but i think these are what tnc outputs for the fe protocol
best regards
peter
FJD, why don't you use TNCServer or TNCRemo for the transmission to the TNC. It is available from the Heidenhain website free of charge (just download it), choose your controller and baud rate and no more settings are required. The latest version of TNC server also handles remote request.
peter
its still not working i even tried to just send the same
programme back that i had just down loaded.
Mouldmaker
Thanks for the info I wasn't aware of those softwares
will see if i can find them.
thanks again
fjd
hi fjd
sorry that hasent worked you are on ext1?
see if you can download what mouldmaker as reccomended
then the next stage is to look at your cable make sure it is configured correctly
2 and3 crossed over
4 and 5 looped
6,8,20 looped
then check program name should be ie: 1234.hnc
then use read in programme
or read in program offered
see how you go with that
best regards
peter
Or you can try calling 1-877-611-5825 and get some support with the editor.
Cadcam
cadcam
I just got off the phone with them got some things to try.
They are going to ck with their dist. in Euorpe and get back with me.
fjd
