587,719 active members*
3,429 visitors online*
Results 1 to 8 of 8
    Jan 2007
    435
    Electronic Edge Finder
    I've looked for a long time for a electronic edge finder with a shank that's 3/8" or less. My machine uses ER-16 collets and so the standard 3/4" shank edge finders won't work for me. Not to mention all the ones I've ever seen are the Chinese made edge finders. I came across this on eBay and thought it might be of interest. I just ordered one and will post my findings here once I get it.
    http://cgi.ebay.com/MINI-ELECTRONIC-...3A1%7C294%3A50
    I also want to say I have absolutely no affiliation with this company or their products whatsoever!
    Jan 2007
    435
    The only downside I see to this one is that I'm not sure if it has any mechanism to protect it from overtravel. All the Chinese models I've seen use a spring loaded ball on the end. But maybe that takes away from the accuracy as well. I've not used one enough to know.
    7063
    Quote Originally Posted by TravisR100 View Post
    If you modify it so Mach can use it as a probe, you shouldn't have to worry about over-travel. I've been using a rigid electronic edge finder as a probe for months, with no problems (I did break one, due to a bug in Mach that's since been fixed).
    Ray L.
    Jan 2007
    435
    Quote Originally Posted by HimyKabibble View Post
    Ray L.
    Any details on your modification?
    Jun 2008
    1082
    Sweet, I've been looking for one of these myself! I put in an order too, thanks for the tip TravisR100.
    7063
    Nothing more than removing the "guts", and figuring out a way to attach a wire to the tip, and bring it out so it can be connected to yoru BOB. On mine, I just machined a plastic plug to take the place of the battery/LED module, and passed the wire in through a side hole, and used the plastic plug to hold it in contact with the tip. A 10 minute mod.
    Ray L.
    May 2005
    2502
    It's real easy, just like Ray said. Rather than machining a plug, I just used the plastic cylinder an endmill came in that happened to fit just right.
    Given that you want an odd size here, you could just machine the whole probe too.
    Cheers,
    BW
    7063
    Quote Originally Posted by BobWarfield View Post
    Cheers,
    BW
    Maybe I'm just a klutz, but I tried making my own, and could not get the accuracy I wanted - best I could do was about 0.002-0.003". But, I did make several I use for non-precision work (like probing and odd shape to generate a CAD file). The advantage of these is an easily replaceable tip (just a small screw), in case I do manage to break it off (which I did, due to a bug in my probing macro before I got it fully sorted out).
    Ray L.
  1. My DIY Edge Finder
    By multiplex in forum DIY CNC Router Table Machines
    Last Post: 05-25-2010, 05:46 PM
  2. Electronic LED Edge Finder
    By drhaasmach in forum CNC Tooling
    Last Post: 12-20-2008, 10:07 PM
  3. Edge finder
    By eggo in forum Australia, New Zealand Club House
    Last Post: 08-04-2008, 04:57 PM
  4. electronic edge finder tips?
    By Rich05 in forum MetalWork Discussion
    Last Post: 07-18-2008, 11:27 PM
  5. Has anyone used this edge finder?
    By l u k e in forum MetalWork Discussion
    Last Post: 03-19-2008, 07:52 PM
