587,446 active members*
3,161 visitors online*
    Oct 2012
    13
    breakout board question
    here is the board I want to buy
    CNC 4 Axis Driver 2M542 4 2A Breakout Interface Board for Router System Kit | eBay
    with this board if one chip (xis ) burns will other still work fully?
    Jan 2010
    2141
    Since no schematic diagram is provided for the breakout board, it is difficult to give a definitive answer. It would depend somewhat on what you mean by "burn out".
    But it would be unusual for one axis of a breakout board to "burn out" because the typical breakout board runs with a fairly low voltage and low current (unlike the stepper motor driver boards that connect directly to the motors).
    Oct 2012
    13
    Thank you for answer but I think I didn explain quite well. the point is that on this board :
    CNC TB6560 4 Axis 3 5A Stepper Motor Driver Board Controller 4 Engraving Machine | eBay
    when one axis controling chip gets burned you cant use board anymore this leads to burning other axis chips.
    Im interested if I build system with this breakout board. and one of axis controler (not breakout board) will burn vcan I just move on with other axis? e.g. I have 4 axis and one burns. can I use it like
    1943
    To answer your question. If one motor driver burns out, the others will work fine and will not be affected by the burned out one.
    Oct 2012
    13
    THank you for answer and dos your answer work for all breakout boards? if one axis burns I can work with others?
  1. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  2. Breakout Board
    By bkkpool in forum CNC Machine Related Electronics
    Last Post: 07-28-2006, 07:15 PM
  3. CNC newbie question Servo+driver+breakout board?
    By wolfmetalfab in forum Servo Drives
    Last Post: 05-11-2006, 07:43 AM
  4. breakout board 200khz option question
    By h_2_o in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 10:52 AM
  5. Question PMinMo Breakout Board
    By huckshooter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2005, 03:46 PM
