587,693 active members*
3,813 visitors online*
Results 1 to 7 of 7
    Oct 2010
    chinese 220v help
    Ok I'll admit I'm not an electrician but I do understand a bit about electrical. I've set up my shop with 220/240v US. The equipment I ordered is 220v, but it's wired with a chinese AS-3112 plug, which is 220v on one leg, neutral, and ground. US 220 is 2x110v legs with neutral and ground. How the heck to I get this to work??? I emailed the company, but it is 1am on a major holiday, I'm not expecting a reply for a few days, and I'd like to keep moving on this setup.
    Here's a photo of the type of plug.
    http://www.zs-sl.com/UploadFiles/20085249116152.jpg
    Dec 2008
    1258
    I am pretty sure this is correct, but then again I'm from England where 240V was the standard...
    You'll need to connect one 'hot' leg (110V) to their 220V, the other 'hot' leg (110V) to their neutral, and then the ground to ground.
    Zax.
    Jun 2008
    69
    Zax is right,
    In this case you don't need neutral. If you can't use your "chinese" plug, simply cut the wire and use your own ( I don't know what kind plug you use in US ), leave the neutral away - but remember connect the ground !
    Hannu
    Jun 2008
    69
    bpoulin,
    Attached is a professional schema
    Hannu
    Attached Files Attached Files
    Oct 2010
    Ok that's what we were wondering, Grnd stays ground, and one leg of each 110 to neutral and hot.
    May 2011
    Just out of curiosity - did you ever get that equipment to work following the scheme that can be found in that thread ?
    24220
    The 220 with one side neutral refers to UK and Australia etc standards.
    See http://www.cnczone.com/forums/laser_...al_system.html
    Al.
  1. 220V/208V?
    By vpmachine in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2011, 07:54 AM
  2. anyone have 220v servos?
    By xclr82xtc in forum Servo Motors / Drives
    Last Post: 06-14-2010, 10:31 AM
  3. Chinese Mill + Chinese accesory + Newbee = Problem
    By csaw in forum Benchtop Machines
    Last Post: 01-24-2010, 05:39 PM
  4. which 220v mig to get?
    By keebler303 in forum Welding Brazing Soldering Sealing
    Last Post: 12-14-2006, 04:06 PM
  5. Yet another 120v to 220v
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 02-24-2006, 08:57 PM
