587,427 active members*
7,089 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > 310 quickchange spindle nut disasssembly
    Nov 2008
    27
    Hi I can't figure out how to get the spindle nut apart on a # 30 quickchange spindle. The nut hits a stop before it is tight on the toolholder. I remove the 3 screws but how does it come apart is there a spring washer or such in there. If I leave the screws out it lets it turn farther to tighten. thanks for all the help
    Oct 2006
    60
    Try putting to longer of the 3 screws in a different hole. It will tighten more
    Nov 2008
    27
    Thanks Its one of those things that are so simple after you know how it works I was trying to take it apart and never did figure what holds the nut from coming off after you take out the screws
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
