Originally Posted by
ngr1
Can I assume, with respect to encoders, that the term resolution and CPR mean the same thing?
The Renco encoders I am looking at have a resolution of 400.
Resolution and CPR or counts per rev. does not always mean the the same thing, but they are tied together.
It all depends on how your control allows you to use the encoder, a 400c/r incremental encoder supplies two square waves 90deg apart (hence quadrature) at 400 counts per rev.
Now some controllers will allow you to increase this resolution by the way it counts the pulses, the minumum would be of course to count the leading edge of one pulse only, this would be 400c/rev, if you count both leading edges then this raises the resolution by 2x, a third option is to count both leading and trailing edges of both square waves which give you 4x resolution of the encoder.
Some controller allow you to choose any option of the three.
Al.
