Is G77 Circular Pocket somewhere in BobCad?
John
John
Gcode routines can be in posts or in scripts added to those posts. You should look for specific scripts or posts to determine this.
Look in the NC cyle or macro menus. If they aren't there then they can be added.
Nothing in the NC Cycle or Macro Menu to do a G77. How do I add it?
John
First off if you refer to the other post you will see the info on creating a script. That includes having Bobcad modify your post (for free) to add this option.
If you create your own scripts then you add those to the menus by using the 'Setup' menu on the NC side. You can add menus to the NC window and have them connected to your script (change the blank line inthe setup window to get your new menu item to show). You can even modify the Bobcad CAD menus but be carefull not to get them screwed up.
