Hello Everybody
I just registered here and got a question.
I'm looking into buying a Tormach 1100 and was wondering if anybody knows about their update cycle?
Is a new one expected anytime soon or is it a good time to buy?
Hello Everybody
The 1100/I launched in 2006. The II in 08, if I recall. V3 was about 2011. Since Tormach has a formal, articulated policy of making major upgrades available to owners of earlier versions (and very affordable!- look at the price of the II to III motion upgrade) there is very little reason to try to time a purchase. My sense is that Tormach does a major upgrade when real functional improvement is possible, and otherwise makes minor updates on the fly, without notice, though they're usually available as retrofits (door latch comes to mind).
If you need one, buy it.
I bought a series I Tormach 1100 back in ’07. All of the improvements to the Tormach 1100 have been available for my series I model as an affordable upgrade. For example I upgraded the spindle VFD and a fan kit for cooling the new spindle VFD braking resistor. Also an essential upgrade added was the power draw bar. I haven’t added the stepper motor upgrade yet, however that upgrade is available at reasonable cost to make my series I a series III. The available upgrades to make older Tormach mills have the same performance as new models is a big plus IMO.
Don
I believe the early Series 1 table is 2" shorter and has 2" less x axis travel than later models, with no upgrade available.
Phil
Phil,
Perhaps on the early series I. Don't know if that's true with my series I. If that is true for mine, I haven't noticed.
Don
Here’s the spec for the early Series I:
- Table Size – 31.5” x 9.5”
- Travel (X, Y, Z axis) – 15.9” x 10” x 16.25”
Here’s the spec for the Series II:
- Table Size – 34” x 9.5”
- Travel (X-, Y-, Z-axis) – 18” x 9.5” x 16.5”
But I think the change happened well before the launch of the series II
Phil
Phil,
Like I said I hadn't noticed the lack of additional travel and table size of my series I as this doesn't have any effect for me with the size of parts I make. I did note the increase in performance with the spindle upgrade: Don't need to change belts as often because of the wider speed and torque range and the increase to 5.1K rpm was appreciated as I machine mostly aluminum. Also noted was the decrease in time to stop the spindle with the new braking resistor- a definite plus when changing tools using the PDB upgrade. BTW I saw a bumper sticker on a small truck like my Tacoma the other day that read: Nice truck. Sorry about your small p***s :-)
Don
Aside from the other good advice, you should know that Tormach is in the final stages of starting production of a surface grinder and CNC lathe. I don't know about the grinder but the lathe has been in development for at least 2 years. If they were working on a new mill, I'd guess that it would be another year or two before it is released, in which case there is little point in waiting.
Mike
Got to see the new lathe in person yesterday, at the Santa Cruz Electronics Open House! It is a LOT bigger than I'd expected, and looks REALLY beefy! Even the stand is massive - made of welded 3/16" steel plates. The headstock is really massive. It'll be interesting to see where the price comes out....
Ray L.
