587,345 active members*
5,305 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Thin plastic engraving material
Results 1 to 9 of 9
    Mar 2012
    378
    I have bought .020" thick reverse engraved and paint filled labels in the past from an engraving company. Now that I have an engraving head for my CNC router I am trying to find the material. Seems that Rowmark, Gravograph, and all of the other companies I have checked only go down to .032" thick material. Any idea where I can get the thinner material from?
    Jan 2013
    14
    Hi brian257:
    I just got a Hermes 7000, and with it I got a sales book from, Gravografph, there may be someing there at Engraving - Gravograph - Rotary and Laser Engraving Systems : engraving software, materials,
    hope this helps.
    Roger
    Mar 2012
    378
    That was where I checked first, but Gravograph does not make anything that thin.
    Apr 2007
    74
    Just looking at Gravograph's web site, and they list 0.020" thick stock.
    Engravable Materials
    I really need a vacuum table to hold this stuff for engraving. Picked up a 2' x 4' sheet for $65 (ouch!) Friday, took a little to dial it in, but coming along.
    Feb 2013
    Innovative Plastics Ulta Thins .004, Peel n Stick .022, Johnson Plastics
    nothing reverse engravable that thin that I can find... What color.. Clear/Clear ??
    In the Great NW!
    Jan 2013
    14
    roundrocktom:
    You can make a vacuum table, use peg board, make a box the size you need, place the peg board on the top with a tight seal, use a vacuum cleaner for the suction, a small one will do, something around 1/2 hp / 1 hp, the sections of the table you are not in need of you can tape off so you don't loose suction, if it's a large table you will need to add supports in the center to keep it from distorting, and to keep you table top flat fore engraving.
    Apr 2007
    74
    Quote Originally Posted by ropanach View Post
    roundrocktom:
    Great idea! Thank You!
    Jan 2013
    14
    Glad I could help. Remember you need good supports under the peg board.
    Feb 2013
    Smile Re: Plastic engraving
    Plastic has not enough strength than the metals...
    SO you have to give the support for it...
    Other wise it doesn't work properly...
    So be careful while engrave the plastic...
    needham-laser.com
  1. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
  2. Any way to limit warping on thin material ???
    By flyinwilly in forum Waterjet General Topics
    Last Post: 03-11-2011, 05:02 PM
  3. Building a Rockcliff out of thin plastic
    By jazzythumper in forum DIY CNC Router Table Machines
    Last Post: 02-28-2008, 04:58 AM
  4. Engraving Plastic Sign Material
    By Dingo745 in forum Engraving Machines
    Last Post: 08-18-2007, 12:39 AM
  5. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-07-2006, 03:16 AM
