587,405 active members*
3,142 visitors online*
    May 2008
    ALARMS 600 AND 607 ON FANUC 6M
    I have a machine with control fanuc model 6M with this failures : over travels -x,+x,-y,+y,-z,+z, faults 600 and 607. I found the limit switch of the x axis wet with coolant I cleaned the switch, but a I still having the alarms.
    24223
    Sounds like you have lost the 24vdc, at least to all the OT switches.
    They are N.C., so with no voltage they appear open.
    Al.
    Jun 2006
    31
    Connection unit or PC card (if exist)may be in trouble
    Jan 2007
    18
    600 & 607 are serious alarms ( communication betweem plc & cnc is bad) you can try with initialization of the bubble memory)
    Mar 2008
    27
    PARTES
    Me llamo Rommel Rojas y vivo en la CD. de Mexico
    tengo partes de control 6m y tengo una maquina con este control
    me gustaria ponerme en contacto contigo por tel para saber mas de tu problema tel 55 2487 9933 [email protected]
    saludos
  1. Fanuc 0t-C 409, 414, 424 alarms
    By acerocket in forum Fanuc
    Last Post: 12-08-2015, 06:56 AM
  2. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  3. Fanuc 400 alarms and other
    By alphatad in forum Fanuc
    Last Post: 02-04-2008, 03:32 PM
  4. Fanuc 0TC with 409 AL-31 alarms
    By bob1112 in forum Fanuc
    Last Post: 07-07-2007, 12:04 AM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
