587,770 active members*
3,243 visitors online*
    Jun 2006
    40
    Fanuc 0t-C 409, 414, 424 alarms
    OK, now I am on to solving another problem.
    I was finally able to transfer a program to the control, but as I went to run it, I get these errors when it runs up the spindle:
    409 servo alarm: (serial err) - after changing the appropriate parameter, it displays SPI=30.
    414 servo alarm: X axis detect error
    424 servo alarm: Z axis detect error.
    Also, diagnostic parameters 0720 (X axis) is 00010000 and 0721 (Z axis) is 00010000. This corresponds to the HCAL bit - abnormal current alarm is being generated in servo amp, check LED. When I check the servo unit in the cabinet, it is displaying an alarm code of 30.
    Even before I was able to transfer programs, I could manually get these alarms by just turning up the spindle RPM. It's not always at the same alarm either. It happens at 1250 rpm, 1400 rpm, 1800 rpm, and sometimes even 2200 rpm. But sometimes, I can run it all the way up to 4800 rpm (my max) with no alarms.
    Some background info:
    I am running in my garage with single phase power. I get about 125V per line from the street so my '220 single phase' runs into a Hammond Power Solutions 24 volt buck transformer. Then into an American Rotary 20 HP rotary phase convertor. At the machine I get the following:
    Line 1 to ground 121V
    Line 2 to ground 99V
    Line 3 to ground 207V (generated leg)
    Line 1 to Line 3 232V
    Line 2 to Line 3 233V
    Line 1 to Line 2 222V
    Does anyone have an idea of how I can fix this problem and stop these alarms from popping up?
    Mar 2007
    18
    Re: Fanuc 0t-C 409, 414, 424 alarms
    I know this is a very old thread but I'm having the same problem and need help figuring out a solution..
  1. Fanuc alarms 479 & 486
    By Antonio Arguijo in forum Fanuc
    Last Post: 08-09-2013, 02:33 PM
  2. Fanuc OP-B Alarms!
    By MagnaFX in forum Fanuc
    Last Post: 04-25-2012, 07:30 PM
  3. Fanuc 0M Alarms 414, 424 & 430
    By Matiwo in forum Fanuc
    Last Post: 07-21-2011, 05:26 AM
  4. Fanuc 0TC with 409 AL-31 alarms
    By bob1112 in forum Fanuc
    Last Post: 07-07-2007, 12:04 AM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
