587,118 active members*
2,955 visitors online*
    Apr 2008
    41
    Milltronics Partner
    I have a Milltronics Partner knee mill that I am getting ready to retro-fit with mach 3.
    I now have only 2 axis, but after I get the x and y axis going I plan to add a z axis.
    I am looking at using the viper drive, and I wanted to know if you could recommend a setup for me.
    Just to look at the specs it looks like the 100v drive would work, but I am concerned about BEMF (back electromotive force).
    My motor specs are attached. (MT30F4-25)
    Feb 2007
    966
    The 100 volt drive (Viper 100) has the same power mosfets as the Viper 200 which are rated at 250 volts @ 56 amps, so the back emf isn't a problem. The difference between the 2 drives is the voltage regulator range (25-100V or 50-170V) and the main capacitor (680uF 100V or 390uF 200V)
    Also i can build the V100 with smaller connectors (10 amp vs 20amp) if requested, for space and cost savings.
    What PS voltage do you plan on running ?
    Larry K
    http://www.viperservo.com/V200.htm
    Apr 2008
    41
    Talking PS Voltage
    I plan on running around 90 volts out of the power supply at 20 to 30 amp.
    the amp. rating is kind of a gray area for me.
    The motors are driving a reduction pulley at 2 to 1, to a .200 lead ballscrew.
    If I have calculated right the spike in amp. shouldn't be over 14 or 15 amps per motor.
    Does this sound right to you?
    And this time I did this time I did attach my motor specs.
    Motor #: MT30F4-25
    Attached Files Attached Files
    Feb 2007
    966
    I just built a chassis with a 1000 watt 90Vdc PS and 3 Viper 200's mounted on their edge. I will post a picture.
    I get the toroids made here in Canada by SumR in Toronto. Costs more than china, but exellent service and quality. I get a 12V 1 amp secondary winding to power the control board in the same transformer.
    Those motors should be no problem.
    No one ever puts a PS capable of driving all 3 motors continuosly at peak current, unless you know the machine will be at 100% load all the time.
    20-30 amps should be fine.
    Apr 2008
    41
    Question To make sure i'm correct
    So do you think that I could get away with 3 Viper 100's or do you see a need for me to have the 200's?
    I thought there might be a reason you used the 200's over the 100's in the 90 volt system you discribed.
  1. milltronics Partner 1
    By Bada Bing in forum Milltronics
    Last Post: 01-26-2009, 06:54 AM
  2. Milltronics Partner I - For Sale
    By Leehound in forum Milltronics
    Last Post: 03-24-2008, 06:27 PM
  3. How to use a VFD to convert Milltronics Partner iv to 1ph
    By ozturbo in forum Phase Converters
    Last Post: 03-22-2008, 10:21 PM
  4. Milltronics Partner ? Centurion V Servo Questions
    By sbalder in forum Milltronics
    Last Post: 02-07-2008, 04:35 PM
  5. Milltronics Partner IV
    By Ben Colby in forum Milltronics
    Last Post: 03-27-2006, 11:53 PM
