587,201 active members*
2,989 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Thread Milling - Conventional - VMX-64 w/UltiMAX 4
    Nov 2018
    We have never done any thread milling before.
    I have looked over some old posts but still have questions.
    We are planning on making M37-1.5 Nuts .3125 Thick
    We have a Kennametal Thread Milling cutter TM25D81L150Z3 and it takes 3 InsertsTM25N150ISO
    They are 25 MM Long with 1.5 Pitch
    1st thing is: Should I tell the Controller it is a Tap or an End Mill?
    There is no thread Mill option for tool type
    I know from what I have seen in posts: Helix is the key to getting it programed.
    I have seen posts that say to Not use Tool Comp and some that say to use Tool Comp
    Any help or guidance will be greatly appreciated
    Quote Originally Posted by W8WCA View Post
    Have you gotten this sorted yet? I'd be glad to help if you still need it.
  1. VMX 24 Door issues Ultimax controller
    By 9566317 in forum HURCO
    Last Post: 04-15-2021, 10:33 PM
  2. Conventional milling in 3D milling option
    By bobhare in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-08-2018, 07:57 PM
  3. Conventional milling
    Last Post: 04-08-2018, 04:18 PM
  4. Climb or conventional milling, which for which?
    By mecanico in forum MetalWork Discussion
    Last Post: 01-15-2015, 11:10 PM
  5. Thread Milling Climb versus Conventional
    By Geof in forum Haas Mills
    Last Post: 06-27-2011, 04:32 PM
