587,771 active members*
3,031 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal retrofit upgrade reusing existing Fadal servo drives and Motors Video
    Jul 2007
    242
    https://youtu.be/zyOEEqa3GLQ
    Apr 2005
    1194
    Re: Fadal retrofit upgrade reusing existing Fadal servo drives and Motors Video
    I would not mess with it unless they can prove the Fadal will work with all its previous functionality and there is a process upgrade. Centroid controls are powerful but there is little to no info on the Fadal swap..or even pricing.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Jul 2007
    242
    actually you end up with more functionality. pricing is available, no problem. and the system is available as a diy system or pro install. typical diy price is in the $4 to 6K range.. and typical pro install starts at $15k with training and warranty.
    call or email us for a quote specific to a particular machine model and year. thanks for looking,
    more fadal retrofit info web page.. Fadal Parts Repair Service 3016 VMC CNC Vertical Machining Center Retrofit upgrade.
    and fadal retrofit video "follow up visit with customer" here.
    https://youtu.be/omd3bIHJe98
    Quote Originally Posted by cnckeith View Post
    Do you know if I can do this with fadal with glentek DC servo drives?
    Joe
    Sep 2021
    Quote Originally Posted by cncguy347 View Post
    Joe
    My first post too, but I just got done doing a full retrofit on our Fadal 3016 with Gelntek DC motors. Way better than the previous Fadal controls but also 20 years newer tech. I'm still ramping up pushing the machine and have a few mechanical issues to sort out, but the electronics and control side is solid.
  1. Early FADAL VMC retrofit
    By dkyuss in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2016, 03:38 PM
  2. Replies: 0
    Last Post: 05-19-2016, 03:27 PM
  3. Fadal ATC - servo upgrade possible?
    By realsquash in forum Fadal
    Last Post: 05-21-2015, 01:39 AM
  4. Using Fadal amps on retrofit?
    By Drassk in forum Fadal
    Last Post: 04-26-2010, 02:09 PM
  5. Anyone retrofit a Fadal VMC?
    By nervis1 in forum CamSoft Products
    Last Post: 12-06-2005, 07:22 PM
