Originally Posted by
Biggermens
Thanks Toby
but that is not the problem i am having right now i made a candel stick but i can get the g-code to open right in mach 3
Ok as I see in the above post you saves as a TEXT File. Have you tried the *.tap or *.cnc file extentions to see if Mach3 will open them?
Mach3 should open text based files, so that has me a little confused. Make sure your saving the Program File in a Folder you can find and try the other file extentions.
Are you next to your CNC now?
Toby D.
Schwarzwald
www.refractotech.com
