587,584 active members*
3,673 visitors online*
Thread: HAFCO VM1
    Nov 2006
    11
    HAFCO VM1
    Hi all, I have just purchased a HAFCO VM-1 mill and intend to convert to CNC. The X & Y axis have about .3mm backlash and I am looking for advice on where to start. Should I pull the whole thing to peices and attempt to replace the screws and nut or is there a way/method of just taking the backlash out of the nuts. Maybe this is enough for me to ask to start with. Thanks Steve
    Aug 2007
    55
    You can get started straight away by using software backlash compensation, it wont be super accurate but it will give you some time to save up and replace your screws and nuts with precision ground ball screws.
    Nov 2006
    11
    Exclamation HAFCO
    Thanks for the info. I have not heard of this before. Can you give me a heads up on any software that does this
    Aug 2007
    55
    Mach3 by artsoft is a good place to start.
  1. Hafco CNC Conversion
    By Johnnysilk in forum Australia, New Zealand Club House
    Last Post: 04-16-2013, 09:30 AM
  2. 4 Axis DRO Fitout to Hafco HM52
    By DMBGO in forum Knee Vertical Mills
    Last Post: 07-27-2009, 01:27 PM
  3. Hafco MetalMaster AL-50GB
    By sl9 in forum Mini Lathe
    Last Post: 04-17-2009, 11:50 PM
  4. Perth Hafco HM35 CNC Conversion
    By XaserTech in forum Australia, New Zealand Club House
    Last Post: 01-09-2009, 01:06 AM
  5. Hafco (Knee) Vertical Mill help
    By midworld08 in forum Knee Vertical Mills
    Last Post: 10-23-2007, 05:40 AM
