587,196 active members*
2,987 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact w/ Heidenhain 151B - Traverse Speeds for Homing Axes
    Dec 2011
    63
    So my next question to you guys is how to control the traverse speeds during the axes homing operation, again with an Bridgeport Interact running the Heidenhain 151?
    I recently learned where the feedrate parameters for rapid traverse (parameters 1 - 4) are different than those used in "PLC Positioning", (parameters 163 - 166). An example of the "PLC Positioning" move is an M25 command (retract spindle) ... which is, evidently, not governed under regular rapid traverse speeds.
    Anyway, the machine seems to home incredibly fast regardless of what I set parameters 1 - 4 or 163 - 166 ... sometimes resulting in the spindle axis (Z-axis) over-running its stops. Interestingly, these speeds do respond to adjustment in the feedrate potentiometer on the control panel.
    Is there a machine parameter governing the traverse speeds during homing?
    Apr 2005
    175
    TNC
    I would take a look at parameters 8 - 10 (11) and 53 (see attachment).
    Dec 2011
    63
    You are correct ...
  1. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  2. Interact w/ Heidenhain 151B FeedRate Question
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2011, 01:54 AM
  3. Bridgeport Interact 1 MK 2 Heidenhain 151
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2011, 11:35 PM
  4. Bridgeport Interact 1 - Heidenhain TNC 151 Monitor
    By mattgatten in forum Bridgeport / Hardinge Mills
    Last Post: 07-04-2010, 09:34 PM
  5. How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155
    By MeTri in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2009, 12:10 AM
