587,789 active members*
4,356 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > C10 Bob to C47 A/C Spindle Speed Controller Wiring
    Apr 2007
    161
    Ok I am trying to figure out how I am suppose to wire from my C10 Controller to cnc4pc's C47 A/C Spindle Speed Controller. The C47 has a network jack for the connector and the instructions only say to connect to their C35 board which also has a network jack but doesn't show a wiring diagram if you want to connect it to something that doesn't have a network jack.
    Here is the C47 Manual
    Link
    Here is the C10, there are several manuals but nothing in really refers to connecting an output.
    Link
    The C47 only has 4 connections in the network jack 5V+, Grd, PWM, Vac/Pump. I won't be wiring in the second relay for this because there isn't enough power on the circuit for both the router and the vac. So disregarding the vac pin. I am not exactly sure how exactly to wire this. I am following their instructions as far as I can. So I put the PWM on Pin 14 of the C10, how am I connecting the 5v+ and the ground from the C47?
    Also something funny with the C47. When I plug in the main 120v input to the card, the two relay controlled 120v default to ON.... So if I power down my computer my router is going to turn on..... REALLY...... is that right...... why would it default to ON instead of OFF???
    Apr 2007
    161
    Re: C10 Bob to C47 A/C Spindle Speed Controller Wiring
    Anyone used a C47 AC Speed Controller?
    Apr 2007
    161
    Ok I managed to get it partially working. I managed to figure it out by looking at one of their other boards. There are only 4 wires used on the C47. 5v, Gnd, PWM, Vac. I ran the +5V to the +5v on the power supply feeding the C10 Bob. PWM went to 14, Vac on 16, and Gnd on Gnd on the C10 output. I get it to turn off and on and I get some variation in the speed but I haven't been able to figure out the pulley settings in Mach yet. I will update when I know more.
  1. Lnc 510i controller, spindle speed.
    By joblo in forum Fanuc
    Last Post: 06-18-2023, 02:55 AM
  2. Speed Controller Wiring Help
    By saabman in forum Charter Oak Automation Support Forum
    Last Post: 12-23-2010, 10:16 PM
  3. Speed Controller Wiring - check me
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 04-07-2009, 02:12 AM
  4. SX3 spindle speed controller (CNC Mode)
    By iGG1e in forum Syil Products
    Last Post: 10-31-2008, 05:32 PM
  5. Micron Spindle Motor /controller /wiring
    By jalessi in forum CNC Machine Related Electronics
    Last Post: 01-12-2008, 01:35 PM
