Originally Posted by
SCzEngrgGroup
Michael,
Sorry, you're right - I wasn't able to watch the video. That looks like a hexagonal being used as a simple single-point broach. I'd be surprised if any normal CAM could be coerced into doing that, but manual programming would be pretty simple, as it's simply plunging, then stepping radially outward from the workpiece axis a thou or two, then plunging again, until the desired diameter is reached. Then, rotate the 4th axis, and repeat. It would be quite easy to write a parametric g-code program that would allow you to enter the hole center, starting and ending diameters, step increment, depth, feedrate and number of "teeth", as parameters, and the G-code would do the rest. However, you'd also want to figure out a way to lock the spindle so it can't turn, because if it turns, the spline will be ruined. I've used this method many times to cut a simple internal keyway. The tool I used was just a 1/8" lathe tool held in a piece of steel rod, with the tool profile ground to the keyway profile. The exact same method could be used here. Make the rod as large as possible, to make it as stiff as possible. Depending on the spline profile, you might be able to use a carbide threading insert instead of a HSS lathe tool. It won't be fast, but it will work, and would cost next to nothing.
Another, much more expensive, option is to buy a rotary broach and holder, though rotary broaching is done in a lathe not a mill. But, it is MUCH faster, and probably a bit more precise as well.
Ray L.
