587,480 active members*
3,339 visitors online*
    Feb 2013
    26
    Need Help Work Holding
    i'm trying to hold down a 1" thick plate 19" x 10" i have to mill two parallel sides and circle mill two bores we are trying to figure out a way to clamp it down that's faster than step blocks and strap clamps. Would like to try something like toggles but the problem with them is we can't put the force on them from the end mill with out sliding the plate. Any Suggestions ?? Any thing at all will help we are trying to make this setup fast and the part change over fast right now we mill the part in a few mins put its taking longer than that to change them out.
    Jan 2004
    3154
    I find Rite Hite clamps to be the fastest manual.
    Can always go with hydraulic swing clamps for production work
    www.integratedmechanical.ca
    Apr 2012
    90
    how about flipping the jaws of a vice to the back of the jaws, then you can just clamp it in the vice.
    May 2009
    26
    Attachment 220972Attachment 220974
    HavingAttachment 220974 a large number of boxes to machine, I made the above Click image for larger version.
ID:	220976jig and used a lever clamp to hold down the work. It was very fast and efficient
  1. Work holding
    By outsider787 in forum MetalWork Discussion
    Last Post: 05-17-2012, 06:59 PM
  2. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  3. Work Holding
    By daveb56 in forum MetalWork Discussion
    Last Post: 12-21-2007, 08:07 PM
  4. Work holding
    By reachraghu in forum Employment Opportunity
    Last Post: 12-11-2006, 01:24 PM
  5. Work holding????
    By anoel in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2004, 06:07 PM
