587,210 active members*
3,355 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Fanuc 31i G65 Macro to G code cycle issue
    Mar 2015
    25
    starting to find more and more issues around this 31i panel that i have never encountered on older fanuc panels when writting custom macro cycles.
    So in short i have created a custom macro G13 cycle to allow me to use some proven Haas programs we have had in use for a no. of years to save rewriting the same programs again.
    so at present im having to call the program via:
    ie:
    G65 P9013 I50. Z-1. D20 F500.
    so at present still have to edit up the HAAS pgms instead of calling
    G13 I50. Z-1. D20 F500.
    i have gone down the usual procedure of setting the G-code name into parameter #6053 to call pgm O9013
    but it refuses to accept the G13 code...
    i have also tried this as another no. so called it O9019 and used #6059 for the G13 call again it will not accept the command.
    Has something else been changed within the 31i software over the older 16M/18M/21i panels that i have not encountered until now?
    May 2008
    77
    Re: Doosan Fanuc 31i G65 Macro to G code cycle issue
    I don’t know what to tell you, I just did this to my doosan mill right now and it works. It’s a 31i model b controller
    Which controller do you have exactly?
    I made an empty O9013 program with a bunch of eob and a m99 at the end.
    Put 13 into 6053 Param
    Went to mdi and put g13 and single block and it switched to program 9013
    Mar 2015
    25
    Quote Originally Posted by soymilk View Post
    The panel is series 31i - model A its on a 2013 doosan hp5000.
    I'm looking at seeing if there are some other settings gs that might require adjustment as I also can't see any of the 9000 pgms other than the ones people have wrote yet it's full of renishaw pgms that you can't see either.
    May 2008
    77
    That’s not how it works. General practice to install the renishaw inspection plus subprograms in the root library folder. Take a picture of your directories
    Mar 2015
    25
    Problem now fixed there was an extra parameter that need altered.
    #11302 needed bit 2 (FPF) turning off as this was stopping me from going any higher up the directory as i was locking into "PATH1" only and could not come out of it to see the "LIBRARY" or "PATH2" once i had access to these i put my O9013 program into the "LIBRARY" folder along with all the other O9000 pgms and the G13 cycle code now calls up the pgm O9013 as i originally wanted.
    May 2008
    77
    Thanks for posting your follow up
  1. DOOSAN PUMA 240 MACRO CODE
    By DANIEL HALL in forum Daewoo/Doosan
    Last Post: 08-04-2017, 12:26 AM
  2. Replies: 5
    Last Post: 07-04-2016, 12:28 PM
  3. Fanuc Macro and G-Code Programming
    By kilogulf59 in forum Fanuc
    Last Post: 11-01-2006, 06:02 PM
