587,722 active members*
3,523 visitors online*
Results 1 to 20 of 23
    Feb 2005
    469
    System Starting Please Wait and wait and wait...
    Went to turn my LC6090 laser on today and I got the usual message on the screen, System Starting Please Wait. That's all the farther it will go and just hangs there. Anyone have any ideas as to what the problem could be? It a 2007 80w USB model running LaserCut 5.0
    The power supply cooling fan is running and I've tightened all the wire connections I can see. Still no win. Any suggestions?
    Dec 2008
    1258
    Skip,
    There are many possible causes, it could be something as simple as a limit / home switch stuck or failed.
    If not, I would suspect the motor drivers or motor PSU (check the fuses).
    Zax.
    Feb 2005
    469
    Thanks Zax. I think it may have something to do with the X stepper driver. The X motor used to make a small clunk when I'd start the machine up but it doesn't do that now. I'll have to dig a little deeper I guess. I'm not sure if there are fuses to the motors or not. I've never seen any but I'll check that too.
    Thanks !!!
    Feb 2005
    469
    update
    I have power to the steppers, the limit switches are good, and I couldn't find any fuses anywhere to check. The motor drives each have a green light and a red light and the green lights are both lit. That's good, right? LOL
    I'm wondering about these two spare chips that they sent with the laser. There's two identical ones on the main board. I hope they aren't soldered. I think if they just pull out and press in, I'll change them and see what happens. Could the problem be that simple? Does a former drill sergeant make a terrible therapist?
    Oct 2010
    Skip,
    If you have a MCP6515 motion control board, the communications chip on it has most likely failed. See if you can run the machine from within LaserCut, if you can do that but still nothing at the operator panel, it is most likely the comm chip on the motion controller.
    Dec 2008
    1258
    If you have power to the steppers it should jog under keypad control, if it does then I agree with Tony it is likely the comms chip. If it won't move then I would suspect the motor controller (not the motor driver).
    I would also suggest looking at the caps on the board, these fail a lot more frequently than the actual IC's.
    Zax.
    Feb 2005
    469
    Thanks Zax and Tony. Yes, it is the MPC6515 motion control board, V 4.0.0.15. I cannot do anything from the laser key pad or the laser controls in LaserCut. The only thing that happens is I turn the power switch key and I get the System Starting message and that is where it says. I did hear the X stepper make the initializing noise (slight clunk) the last time I tried to start it, so I know it's getting power.
    Here's a couple of pictures that may help with the trouble shooting. Are those fault lights on the lower left side of the motion control board? There's eight lights there top to bottom. I don't remember having more than two lights before. I think the bottom one was lit and the top one was flashing before my troubles.
    Thanks much !!
    Skip
    Attached Thumbnails Attached Thumbnails IMG_0891.jpg   IMG_0893.jpg   IMG_0892.jpg   IMG_0894.jpg
    Oct 2010
    There is an error on your board. It is reading out a config file error. If you can download a new config file try that. This might not work if there is a communication error.
    Feb 2005
    469
    I will try that, thanks Tony.
    Nov 2010
    787
    That is common problem with MPC6515 and PAD03.
    You just lost connection between mainboard and control panel.
    Check black cable connection.
    Special connctor under PAD03. Clean it with alcohol.
    You should take wires out of white connector, clean them and put back fastening.
    It works.
    Feb 2005
    469
    Quote Originally Posted by cinematic2 View Post
    It works.
    Where were you 2 weeks ago with this information???... :wave:
    I put a new MPC6515 and keypad on it. Dean over at legacylasers.com gave me a great deal on the parts. I also upgraded the software from LaserCut 5.0 to ver. 5.3.
    And what is really amazing is that I had a 3 1/2 year old spare 80w laser tube sitting on a shelf that I had bought new with the laser. I installed it last week and it works just like a new one. I'm pretty happy about that. I don't know how long it will last but as of right now it is working great.
    Nov 2010
    787
    What is a great deal?
    Mar 2011
    I have a mpc6535 with a similar problem, all i get at pwr up is the system starting please wait message.
    This started after the machine would not home with the datum button, the whole system would hang after it was pushed.
    To try and find a work round the auto datum option was ticked in the config and saved. Now it won't go passed the start up message.
    If plugged i plug it into a pc the pc will load the drivers correctly, but laser cut comes up with a comms error so i can't send a new config file.
    Is there any way of resetting the mpc ?
    I have ordered a couple of units to replace this one but would like to fix it if possible.
    Thanks.
    Mar 2012
    Help me 2 please
    I have simmilar problem with my mpc6515 it has lights flashing on it but wont intalize properly it was working fine day before i moved it across my shed and them it stoped working. 2 lights on the front board flashing the one on the left flashing on and off slower than the one on the right and on the main board the top led is flashing on and off about every second please help it is driving me nuts
    Feb 2005
    469
    MPC 6515 Manual
    Here is the zipped 6515 manual. Chapter 8 describes the indicator lights and faults. Hope this helps you figure out your problem.
    Attached Files Attached Files
    Mar 2012
    I have cleaned the connector and soldered the wires to the connectors in the white box then reconnected the PAD03 the problem still persists so now I have ordered new darlington array chip's like ones in SkipW's pic I also ordered a new TLC5615CP IC, can any one tell me what IC is the communications chip on the main board ?
    Mar 2012
    divid this is exact same problem i am having but I tried to start the mpc and pressed stop on the keypad it worked for a second then i restarted and same problem i am going to solder the wires direct to the pad03 and see i will post reply in few i am going to do it now
    Mar 2012
    I did the soldering thing and still prblem is there this is driving me nuts.. can anyone tell me what chip is the comunication chip on the main board ?
    Nov 2010
    787
    I would buy new PAD03.
    CNC lasers, constructions, service
    May 2014
    Re: System Starting Please Wait and wait and wait...
    Hello! i have same problem. Any idea how to solve this?
  1. TTS : Why did I wait so long?
    By keithmcelhinney in forum Novakon
    Last Post: 10-03-2013, 08:30 PM
  2. Replies: 2
    Last Post: 09-09-2013, 12:51 PM
  3. fallo: starting system please wait.
    By abece in forum Spanish
    Last Post: 03-28-2013, 01:20 PM
  4. can't wait
    By clammy23 in forum Commercial CNC Wood Routers
    Last Post: 03-03-2008, 01:16 AM
  5. Should I get 5.0 or wait for 6.0, or
    By fc911c in forum Visual Mill
    Last Post: 03-01-2007, 04:26 PM
