587,691 active members*
3,512 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > how to adjust rapid plane clearance
    Sep 2011
    38
    we tell mill to go to 0 in mach3 it will . we start program
    quill comes up and travels to starting point of first drill hole hole then drills and raises to top of part with .1 clearance
    after first hole i want more vertical clearance to clear fixture mounts
    after first hole is complete quill raises up to top of part i need top of part + 1/2 "
    i think this is called rapid plane what am i doing wrong
    PLEASE PLEASE HELP
    harry
    May 2013
    701
    Quote Originally Posted by hmoore01 View Post
    PLEASE PLEASE HELP
    harry
    I really hate to even comment on this but, I think only real safe way is to make your stock as a STL solid and include your clamps as part of that solid.
    Maybe someone else will have a better way.
    Apr 2009
    3376
    A quick search,this has been discussed a lot
    http://www.cnczone.com/forums/search...archid=1376641
  1. Default clearance plane
    By BurrMan in forum BobCad-Cam
    Last Post: 02-21-2014, 05:42 AM
  2. Feed Plane Overwriting Rapid Plane V26
    By Jbrown74 in forum BobCad-Cam
    Last Post: 02-21-2014, 02:17 AM
  3. mastercam check surfaces and clearance plane
    By VBUZZ in forum Mastercam
    Last Post: 12-06-2013, 08:01 AM
  4. Z goto rapid clearance
    By manmardam in forum Mach Software (ArtSoft software)
    Last Post: 05-20-2010, 09:49 AM
  5. Clearance / Feed plane - Absolute/Incremental
    By jcnewbie in forum Mastercam
    Last Post: 10-09-2009, 05:32 AM
