587,793 active members*
3,569 visitors online*
Thread: X3 Gas Strut
    Apr 2007
    151
    X3 Gas Strut
    The gas strut on my X3 has gone west again, as Hugh is out of stock does anyone know the newton rating of these stuts? so I can buy one that has more lift.
    I suspect the ones fitted by Syil are under speced, has anyone else had this problem
    Would Syil care to comment?
    Mike
    Apr 2007
    151
    Solved the problem!! Gas struts have an oil seal on the cylinder, with the cylinder at the top the oil flows into the seal, however if the cylinder is at the bottom oil flow away from the seal and it dries out, result strut failure.
    Syil in all there wisdom are installing the gas struts upside down.
    I would be interested to hear from Syil regards this matter
    Mike
    Jun 2007
    3735
    You can recharge it.
    Put in a piece of pipe, seal it and add compressed air.
    Only needs setting to 35-40KG. Original Syil charge is too high, and makes the head 'dance' on it.
    Yes, put the thin part down.
    Better still add 80+mm to the Z travel...
    Replace gas strut on X3 - New struts or maybe counter weights? - CNCzone.com-The Largest Machinist Community on the net!
  1. Replies: 20
    Last Post: 01-04-2013, 12:01 AM
  2. X3 gas strut only on some models ?
    By topls64 in forum Benchtop Machines
    Last Post: 06-16-2008, 06:17 AM
  3. Replies: 11
    Last Post: 08-06-2007, 01:25 PM
  4. Grizzly X3 mills - No gas strut?
    By wisp in forum Benchtop Machines
    Last Post: 01-30-2006, 10:44 AM
  5. Uni-Strut
    By cbcnc in forum Composites, Exotic Metals etc
    Last Post: 03-20-2004, 06:59 AM
