587,925 active members*
3,294 visitors online*
    Nov 2004
    70
    BALLSCREW BACKLASH
    WE HAVE A CENT VI . IT HAVE A .006 BACKLASH , IT THERE A WAY TO TIGHT
    IT . OR REPLACE THE BALLS LITTLE BIGGER TO COMPENSATE PLEASE HELP
    ANY ADVISE THANK YOU
    Jan 2007
    206
    is this on a mill or lathe? what model?
    The Farmer
    Oct 2008
    427
    You need to find out where the 'slop' is. Work your way through every component-to-component connection until you find what's loose.
    Start with the motor-to-encoder connection, then go on to the motor shaft-to-sheave, the sheave-to-belt, the belt-to-sheave, the sheave-to-ballscrew, the ballscrew-to-ballnut, the ballnut-to-carrier, the carrier-to-table/saddle/bolster. If you have a direct-mount motor, check the coupling, etc.
    You also have to check the thrust bearings. They trap the ballscrew to the fixed part of the machine so that the ballnut can move the axis. The pre-load on the bearings prevents the screw from moving relative to the saddle/base/column.
    You should be able to get the backlash down to a few tenths.
    I usually find the bearings are the problem but you have to check the rest to be sure.
    Good luck with your search.
    Dec 2012
    569
    Quote Originally Posted by ZZZZ View Post
    this was exactly the case on my 1990's DM2900 mill. ihad to preload the thrust bearings by turning the ball screw "tang" while holding the pulley that drive it in place, then locking it all together while under tension using a special lock washer
  1. ground ballscrew backlash
    By nc_machine09z in forum Machines running Mach Software
    Last Post: 06-12-2012, 06:17 AM
  2. 3016 ballscrew backlash
    By Daniel Boone in forum Fadal
    Last Post: 07-20-2010, 07:00 PM
  3. Ballscrew backlash, need suggestions.
    By magick_man in forum DIY CNC Router Table Machines
    Last Post: 05-05-2007, 11:36 AM
  4. Backlash for a rolled ballscrew?
    By Zumba in forum Linear and Rotary Motion
    Last Post: 03-20-2006, 10:41 PM
  5. Ballscrew or Backlash Compensation?
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 11:47 PM
