587,281 active members*
3,313 visitors online*
    Oct 2007
    Metal Recovery Technology
    Hello guys
    I wanted to share this info with you. As I was doing some research on new alternative for metal recovery systems I found a new technology called the Rotating Electrode. It can recover metals in solution (into a metallic form) before it goes to the wastewater treatment.
    Here is the link: www.globalionix.com
    May 2006
    8
    Hi zoulume. I have visited globaIionix.com. I wonder do you have some information about metal recovery homemade using electroplating system?
  1. coolant recovery vacuum?
    By cncatj in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2007, 01:44 AM
  2. NSH TF Turbine Oil Recovery plant
    By sinonsh22 in forum News Announcements
    Last Post: 11-06-2006, 07:52 AM
  3. Sino-nsh LV Lubrication Oil Recovery machine
    Last Post: 10-26-2006, 07:05 AM
  4. Sino-nsh Gas Engine Oil Recovery Secondary
    By sinonsh22 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-13-2006, 07:02 AM
  5. Why doesn't discuss the technology?
    By hkxy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-10-2006, 06:05 AM
