I have a sample program written in notepad. Every thing is set to go . My problem now is importing files. I saved the file in notepad copied it to a floppy disk. I went to my machine and copied this to the Turbocnc folder on the c drive. I opened the file went to properties for the location of the file. I booted up in ms-dos to run Turbocnc when the screen came up I went to file and then run from file. Could not get it to open. I have read the docs but can't find a step by step instruction. I know it has to be a txt extension on the file name. Is file extension default or is it part of the ini file.
Can someone help me?
Mike Burts
305 Burts Garage Rd.
Anderson SC 29626
Ph.864-224-7826
Fax864-224-7232 E-mail [email protected]
