587,608 active members*
3,428 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > fire clay/fire rock
Results 1 to 11 of 11
Hybrid View
    Feb 2009
    87
    fire clay/fire rock
    Is fire clay and fire rock the same thing? I just got around to getting the supplies rounded up to make a small foundry and noticed when I got home they give me fire rock instead of fire clay. Reading the label says it's a mortor for laying brick fireplaces.
    If not the same, will this stuff work? I'm mixing up the home brew refractory, Fireclay, sand, perlite, and portand cement.
    Made the propane burner already, that thing is cool. Well..........hot.
    Have a great day,
    Bob
    Apr 2004
    5749
    Quote Originally Posted by banctecbobn View Post
    [Fireclay is a clay, it's a generic ingredient. FireRock mortar seems to be a proprietary system for putting together synthetic refractory panels to create FireRockTM fireplaces; I'm not sure what's in it.]
    [That's not going to work too well, even if you find real fireclay. Perlite isn't refractory enough to stand up to metal-melting temperatures, and portland cement gives up its strength at those temps as well. Sand goes through quartz inversion at high temperatures, which causes a change in particle size (not good). Do yourself a favor and spend 50 bucks or so on some real castable refractory material, that you won't have to chip out and replace after a few melts.]
    Have a great day,
    Bob
    [Is that a passive air-induction burner, or are you using a blower with it? Blower burners melt quicker and more efficiently; passive burners are good for forges, less good for melting furnaces.]
    Andrew Werby
    www.unitedartworks.com
    Feb 2009
    87
    Thanks for the reply.
    50 bucks or so for real refractory?????? It going to be over 200 bucks for real castable refractory. I know or I should say I've read that the home brew will not hold up for a long time, but I think it will hold up enough to find out how interested I'll in this hobby. I didn't know if I could use the fire rock in place of the fire clay.
    No blower, just the burner (Ron Reil design).
    Dec 2004
    1865
    Quote Originally Posted by awerby View Post
    Andrew Werby
    Hi Andy and not to hijack this thread, any links to the blower kind of setup.
    Hi awerby, I am hoping to start some work on the foundry ass well this winter and I understand that "real" refractory is REALLY expensive.
    How about some pics of the cool(hot) burner.
    Let us know how you make out.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Apr 2004
    5749
    How big a furnace are you building?
    Okay, it's been a while since I bought this stuff, but it's still not super expensive for what it does. Here's a link: http://www.budgetcastingsupply.com/C...Lite-26-LI.php
    $110 gets you enough for a small furnace; 2 bags should be enough for a medium-sized one.
    Here's some that's less expensive per bag, but about the same by volume, although it's rated to higher temps:
    http://www.continentalclay.com/detai...ID=45&PID=1015
    All that clay and cement is going to cost you something too, and then you've got the labor and expense of replacing it when it goes bad. Do it right the first time, and you can concentrate on casting metal and not furnaces.
    Here's a link to instructions on building burners:
    http://mikegigi.com/burner.htm
    His blower burner is a lot like mine, except I think he's using the wrong sort of blower. A "squirrel-cage" blower like he shows will be better than nothing, but to get the most out of your gas you should use a pressure blower. That will do a better job of forcing air into the burner against back-pressure, where the squirrel-cage just spins. I've used vacuum cleaner blowers with good success.]
    Andrew Werby
    www.computersculpture.com
    May 2008
    20
    3000 deg F castable
    Just my $.02...
    I am in the process of building a cupola based on Steve Chastain's book since I have quite a steel scrap pile from work. I called my local boiler repair place and bought a 50# bag of 3000 deg castable for $31.80 incl tax. They also sell 2" ceramic blanket for about $7.00/sq.ft. I am going to have a 1" thick hotface of dense castable and insulate it with the blanket. I would exhaust all local resources before having bags of stuff shipped; I looked under the yellow pages headings of "ceramics", "pottery", "brick suppliers", and "boilers" and cold called them to see what they could offer me.
    NearBeer
    Feb 2009
    87
    I have just over 50 bucks in materials to build the foundry, if I can use the fireclay. It would take two or three of those 100 plus bags of refactory to do the same job. Don't get me wrong, I agree using the refractory over the home brew would be best. I want to see how interested I'm in this hobby before I put much money into a foundry. Most people that build a foundry always wish they did something a bit different in the build. If casting is for me, I can later build a second foundry more to the size I need and design that suited for me. I won't know this until I have one to use.
    If I could find refractory for 30 bucks a bag in Indpls, that is the route I would start with.
    Does anyone know if the firerock will work or do I need to return this stuff?
  1. Smoke and fire...yes FIRE!
    By fatal-exception in forum Gecko Drives
    Last Post: 01-25-2008, 08:58 PM
  2. Fire Rings
    By millerrocks06 in forum News Announcements
    Last Post: 03-31-2007, 09:08 PM
  3. Cannot get my torch to fire?
    By Redline in forum Waterjet General Topics
    Last Post: 08-27-2006, 03:45 PM
  4. Yet another iron in the fire...
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 07-03-2006, 05:27 AM
