587,913 active members*
3,601 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > ALARM ISSUE: LC20-M With OSP5000L-G Control
    Apr 2008
    We have just acquired a LC20-M, a great machine, and have brought back to life the live tooling through the use of modern programming software.
    The machine and program are working great except for a random (sometimes not so random) alarm we get when the machine tries to engage the C-axis for the live tooling. The spindle will rotate slowly, stop, and then there is a clicking sound as if the C-axis is trying to lock up or engage. The machine pauses for a few seconds and you hear a second click. The “C-AXIS ENGAGING” light on the control remains flashing (should be solid when engaged correctly) and the machine alarms out with the following:
    ALARM-A160 C AXIS CONNECT COMMAND
    Any ideas on how to correct the problem is appreciated.
    Jan 2008
    575
    What code do you use to engage it(the C axis)? Robert
    Apr 2008
    Quote Originally Posted by littlerob View Post
    M110 ENGAGE
    M109 DISENGAGE
    Jan 2008
    575
    The reason I ask is that think the alarm is a programming error, or possibly a parameters error. Sometime I get that alarm if I haven't turned off the spindle BEFORE the tool change. (Home the turret, turn off the spindle M5, then do the tool change) Hope that helps, Robert
    Apr 2008
    Thanks Robert, I will look into it and let you know.
    Sep 2008
    5
    NEED HELP !
    I have an OKUMA&HOWA millac 4VA,System OSP5000M but it was alrm : 054 "P"
    140006F
    Please help me !
  1. Replies: 2
    Last Post: 11-26-2007, 04:33 AM
  2. Lathe program/alarm issue
    By kperk12345 in forum Okuma
    Last Post: 10-11-2007, 07:57 AM
  3. Cincinatti 900 V2 control issue
    By mrpmzrq in forum DNC Problems and Solutions
    Last Post: 09-21-2007, 01:12 AM
  4. siemens control speed issue
    By pioneerdean in forum Uncategorised MetalWorking Machines
    Last Post: 12-29-2006, 07:58 AM
  5. Help!! Surfcam Issue-Mori Seiki Control
    By MachineManOK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2006, 06:52 AM
