I have read through numerous post in recent days regarding converting Mastercam 8 files into Autocad 2007 files and everything seems quite straight forward however I am in need of doing the reverse operation.
I have been trying without much luck to access and use a *.dxf file created by Autocad 2007 in my Mastercam 8. To do this I have simply been creating the drawings in Autocad 2007, saving as a *.dxf file and then using the File -> Converters -> Dxf option to try and import my drawing into Mastercam 8.
The problem is that Mastercam after this process I am left with a blank page where my drawings should be. Can anybody please help point out where I am going wrong? If you require any further information to be able to help I will happily post the requested information asap.
