587,460 active members*
3,622 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Fusion and RichAuto Controller
    Oct 2010
    47
    Hi all
    I have an interesting problem when using Fusion with a RichAuto A11 controller. I have a cnc machine at my school with an A11 controller. Any code from VCarve responds correctly. Any GCode from Fusion responds incorrectly. Eg drilling 4 holes at the corners of a wooden stock piece just results in the machine travelling to the four locations and then finishing, no Z movement , no drilling. If I use the same code at home on my own CNC with an A18 RichAuto controller it works fine. Controller issue I think but it’s doing my head in!
    Any thoughts?
    Many thanks
    Scott
    Jan 2018
    1516
    Quote Originally Posted by sli21 View Post
    Hi all
    Any thoughts?
    Many thanks
    Scott
    Daft question but:
    You have set up the correct post output in Fusion, yes?.
    Oct 2010
    47
    Re: Fusion and RichAuto Controller
    Quote Originally Posted by dazp1976 View Post
    Daft question but:
    Hi there
    Thanks for responding.
    Using grbl pp. occurred to me that the working vcarve file is referenced off top of stock. Fusion is referenced off bottom. Changed to stock top and it works fine. Something to do with z axis setup in the RichAuto controller. Annoying but I will find out what it is.
    Cheers
  1. Problem with RichAuto A11e dsp controller
    By MustafaNsr in forum Commercial CNC Wood Routers
    Last Post: 03-16-2023, 04:54 AM
  2. Richauto A11 DSP controller problem
    By atled in forum Controller Cards
    Last Post: 04-08-2019, 03:36 PM
  3. RichAuto controller issue
    By bonerbill in forum USA Club House
    Last Post: 09-30-2016, 07:43 AM
