587,515 active members*
2,986 visitors online*
Thread: Cut2D 1.5
    Dec 2010
    61
    Cut2D 1.5
    Seasoned Cut2D users...Is there a setting I'm missing...I need to cut on just a straight line, but Cut2D informs me that a straight line is not a vector and will be ignored from the tool path, is there a workaround for this...
    Thanks in advanced
    Sep 2011
    1183
    Did you use the draw polyline I tried and it works for me..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Apr 2007
    8082
    If you use a Profile tool path it should ignore the closed vector requirement.
    If you want a V-groove or concave groove instead of a flat bottom cut that you get with a flat tip end mill, just insert the V-bit or ball nose tool you want to use and let the software keep thinking it is a flat nose end mill. You will need to set the maximum depth of cut you want in the software settings as usual for a profile cut. You have the options to cut on the vector or to either side of the vector.
    You will not see a V-groove or concave groove in the simulation though.
    It works this way in Vcarve Pro. I assume that Cut2D has similar capabilities.
    CarveOne
  1. Cut2D
    By steeltoes in forum Cut2D / Cut3D
    Last Post: 03-09-2013, 02:53 PM
  2. What CAD to get for Cut2d?
    By forrest39 in forum Vectric
    Last Post: 10-30-2009, 04:45 PM
  3. Cut2D - Can It Do this?
    By noisillator in forum Vectric
    Last Post: 06-19-2009, 05:43 PM
  4. Cut2D
    By voltsandbolts in forum Vectric
    Last Post: 04-27-2008, 04:35 AM
