High pitched whine.
Good to hear you got it working.
The whining is the VFD CHOPPING the supply to the motor which is the way it makes the 3 phase power. Some questions...
1). What have you set the current limit setting to?
2). Can you measure the input mains with a tong tester?
3). What is the motor plate ratings.
4). Does the motor plate have details of the wires as you describe them?
It is probably a dual voltage motor. If that is how the wiring was don't change it unless you have a reason.
5). Was it originally run on 220v 3 phase?
