587,082 active members*
2,820 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Drill cycle on a Fanuc 11m control in a Kuraki boring mill
    Jan 2009
    The normal program drills with the quil or "w" since it is a boring mill.
    G83 x1. y1. w-1.340 Q .1 R.1 F2.
    I'm looking to get a closer rapid return than .1 and it won't read a "P.02" for instance. Any help is much appreciated. Thanks.
    2932
    My 11M-A manual says that the return distance for G83 is set by parameter #6211. P is a dwell time at the bottom of the hole in G82, G88 and G89.
  1. canned cycle for lathe with fanuc control
    By JPann in forum G-Code Programing
    Last Post: 09-27-2011, 06:45 PM
  2. Drill cycle for FANUC
    By slowhandd in forum Commercial CNC Wood Routers
    Last Post: 02-26-2008, 05:02 AM
  3. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
  4. Canned Cycle G73 Om Control Fanuc(drill)
    By marrieche in forum Fanuc
    Last Post: 03-05-2007, 11:51 PM
  5. Replies: 2
    Last Post: 01-20-2006, 08:39 PM
