587,216 active members*
2,936 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > bridgeport interact 1 cant get power to come on
    Jun 2009
    5
    Lightbulb bridgeport interact 1 cant get power to come on
    Hi my problem is on turnining the machine on,when i press the green power on button the machine trips out the mains.
    Now when i turn the power on no nothing is lighting up at the screen.
    I have checked all the fuses they are OK.
    The machine has a tnc 145 control.(any thoughts)
    Nov 2004
    3028
    The TNC-145 has a fuse in the center of the voltage dial on the back of the control. Did you check that one?
    Check power in, how all the transformers are configured, and hopefully you are using true 3 phase power.
    George
    Jun 2009
    5
    thanks for your speedy replay i will check for that fuse in the morning
  1. Interact 308 Bridgeport ?/:????
    By SGARCIAM in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2008, 10:22 PM
  2. CNC Bridgeport II interact 4 Tnc 150
    By frenk59 in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2008, 01:49 PM
  3. Bridgeport Interact 1 MK2
    By Leyland 472 in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2006, 12:44 PM
  4. Bridgeport Interact Series II Power Drawbar
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 09-16-2006, 01:27 AM
  5. Bridgeport Series 2 Interact 2 Power hook up problem! Help!
    By Huntersyv in forum Bridgeport / Hardinge Mills
    Last Post: 01-09-2006, 08:57 AM
