587,166 active members*
3,988 visitors online*
Thread: 410 fault
Hybrid View
    Aug 2005
    36
    410 fault
    we have an older komo router with a general numeric control and eg&g drives. We are getting a 410 fault in x axis the position deviation amount during stop is greater than the setting value. we have swapped the x and y servos and boards it always stays with x axis. any help would be great. thanks
    Aug 2007
    793
    Re: 410 fault
    how much is error during stop?
    do you have separate encoder on the screw or controller uses signals from drive? in this case backlash would cause that phenomena
    you may change in-position width during stop parameter
    or increase position loop gain
  1. Siemens Sinodrive Fault But No Fault
    By Rockwell Guy in forum Servo Motors / Drives
    Last Post: 04-27-2013, 05:46 PM
  2. Z Axis fault Error #16 Resolver Fault
    By centaur91 in forum Fadal
    Last Post: 10-06-2012, 05:01 AM
  3. 139 x motor z fault and occasional ground fault
    By duckslayer in forum Haas Mills
    Last Post: 05-10-2012, 01:50 PM
  4. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  5. Inverter fault / Drive line fault ?
    By TMILLS in forum Fadal
    Last Post: 10-21-2010, 03:20 AM
