587,858 active members*
3,783 visitors online*
    May 2003
    267
    Removing rust from THK rails
    I have some THK linear rails and bearings that are rusted. What is the best and safest method to remove the rust? I tired Navel Jelly with some wire brushing, but it still leaves some rust on the parts.
    Also, how do I get the THK rails shinning like new? Since the ball bearings will make contact with the rails, I want the contact points as clean as possible.
    May 2005
    1810
    If they are rusty, they are gone.
    Sorry to hear about your loss. My sincere condolences to you and your machine.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Jun 2004
    487
    Hi. I bought 4 rails that had a bit of rust on them and got it out with WD-40. You might want to soak the whole thing in it overnight. Once clean, lube with (the very expensive) THK grease.
    JR
  1. Joining two THK SHS15 rails
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 05-25-2005, 02:16 AM
  2. How close can I space THK rails?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 12-31-2004, 06:13 AM
  3. Wrong THK rail - Help!
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-17-2004, 07:26 PM
  4. extending THK rails, rail alignment
    By Cliff_J in forum DIY CNC Router Table Machines
    Last Post: 05-28-2004, 06:09 PM
  5. Can I Cut THK Rails?
    Last Post: 09-15-2003, 10:45 PM
