587,858 active members*
4,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > WTB Dyna Myte 3000 Lathe and 2800 mill
Results 1 to 7 of 7
    Feb 2008
    I am looking for a Dyna Myte DM3000 and a 2800 mill. Working machines or parts machines considered. Any leads appreciated.
    Thanks!!
    Jan 2012
    Dyna Myte 3000 lathe
    I have a Dyna myte 3000 lathe. It needs work. Some one blew out the control messing with the x axis resolver. It has a very heavy table with it. I can send pictures. It has been sitting a long time so there is stains on the ways. I will take 750.00 for it where is as is. I don't think it has ever been run. The machine with table I am guessing weighs 1500 pounds. I am in Eden Utah.
    Jul 2010
    172
    Where are you located?
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
    Jan 2012
    Dyna myte 3000
    I am in Eden Utah. The machine with table weight i am guessing is 1500 lbs.
    Jul 2011
    Dynamyte 2800
    I have a Dynamyte 2800 for sale.
    We got it in with no history, and spent a while to get it running.
    It has an onboard PC running DOS and a proprietary 4M Program. The PC was in bad shape; it wouldn't boot properly. The hard drive it came with was failing, and after cloning it to a new drive the computer booted properly.
    It worked flawlessly the first times it turned on. We saw all the motors were functioning properly including the spindle. After a day or so it began to throw back error codes.
    I have since been unable to give any attention to it, but I am sure it's just a silly electrical short away from being a fully functional CNC mill.
    On a side note, I was hanging on to this machine because I believe it would be an excellent candidate to retrofit to LinuxCNC or a similar application.
    You can get back to me at vittorio.alfieri [at] alpha-logix.com
    EDIT: I am in Brownsville, Tx
    Jun 2005
    87
    I am also looking for a DYNA Myte 2800 if anybody knows of someone that has one that is a needing a retrofit. [email protected]
    Nov 2014
    Re: WTB Dyna Myte 3000 Lathe and 2800 mill
    Hello, just joined.. I know I am responding to an old post but I purchased a dyna myte 3000 cnc lathe a few years ago and hope to learn more about it..anyone running one of these with the original controls?
    I may also be interested in selling.. It is in excellent shape, and works great.
  1. dyna myte 3000 lathe
    By davidponte in forum Dyna Mechtronics
    Last Post: 01-27-2013, 04:50 AM
  2. dyna myte 2800/3000 to greco systems
    Last Post: 11-14-2011, 01:52 AM
  3. dyna myte 3000 lathe
    Last Post: 04-15-2011, 05:02 PM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
  5. DYNA MYTE 3000 BENCH-TOP CNC MINI-LATHE
    By TitaniumCannons in forum Benchtop Machines
    Last Post: 12-10-2009, 06:30 AM
