587,418 active members*
3,670 visitors online*
    Jul 2003
    71
    Speed and Feeds problems
    I am milling some 6061 Aluminum with a 1/32 ball endmill.
    I have so far busted 2 of them and I just ordered some 1/32 OSG Exocarb-BN ball endmill.
    My main problem is my max spindle speed is 10,000
    Does anyone have any suggestions for spindle speed, feed rate, and Depth of cut.
    The cut I have to make is at the deepest is 0.015
    Any help will be great,
    106
    I haven't run any mills that small but I have done some detail engraving with a 1/16 ball nose in 6061 Aluminum. My depth of cut was only about .010, and I too am limited by the 10,000 rpm spindle. I ran wide open at 10,000 rpm's and a chip load of about .0002 on my 2-flute ball-nosed end mill which figures out to be about 4.800 ipm. And plenty of flood coolant was used. You may have to slow your feed down a bit more since the mill is so small, maybe start around 3.00 to 3.50 ipm. Good luck.
  1. High Speed Spreadsheet
    By MachineSMM in forum Hard / High Speed Machining
    Last Post: 05-21-2014, 01:57 AM
  2. feeds and speeds
    By Mortek in forum Hard / High Speed Machining
    Last Post: 12-31-2004, 07:06 PM
  3. 1/4 Carbide Aluminum Feeds?
    By Cold Fusion in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2004, 02:59 PM
  4. feeds and speeds
    Last Post: 02-28-2004, 10:59 AM
  5. Rpm and Feed Rates
    By Xeno in forum Uncategorised CAM Discussion
    Last Post: 02-23-2004, 11:06 PM
