587,758 active members*
2,777 visitors online*
    Mar 2013
    116
    Font size problem??
    I loaded Mach3 on a new Computer win7. Now I can only see 66% of the top of the fonts on all screens? I can't seem to reset the fonts to something smaller?
    any Ideas
    CH
    Re: Font size problem??
    Make sure your font setting in Windows is set to normal size.
    Jun 2007
    3735
    I had similar problem.
    18 pt Arial seems to work well
    Installing Arial Narrow on the computer for labels, code and buttons might help (if it is not installed)
    General config --> screen control. Turn off hi-res screens
    Mar 2013
    116
    HI
    Never mind Got if figured out, I'm new to Win 7 so I'm still learning here. I have to reduce the text size % in the Win7 display settings. I dropped it from 125 to 120% at least I can still see it with these old eyes.Thanks guys.
    CH
    You didn't do what I said, The issue is your Windows font size setting. It's not a resolution setting. Go to Control Panel in Windows, and click on Display. The fonts need to be set to 100% (Smaller setting).
    You can't change the Font size in Mach3, even though it appears that you can. They are locked at 18.
    Jun 2007
    3735
    I haven't been able to change size from 18, but can change font.
    I select Arial Narrow, then immediately goto config, save settings then exit and restart Mach3
    Looking at your screen, I think it is a crappy video driver scaling problem, as all vertical dimensions are squashed.
    Try different video settings.
    Aspect ratio options: full, no border, <<<-----
    1366 x 768 or 1024 x 768.
    Edit:
    Gerry is correct.
    Right click windows screen,Screen Resolution,
    make text and other items larger or smaller
    Select 100%
  1. font size on mach3 mill
    By millwizard in forum Mach Mill
    Last Post: 08-14-2009, 05:14 AM
  2. Change NC Fadal font size
    By car_guy_549 in forum Fadal
    Last Post: 07-17-2009, 07:55 PM
  3. Can you adjust the screen font size ?
    By a1a5115 in forum Fadal
    Last Post: 04-16-2008, 04:48 PM
