587,203 active members*
3,274 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam dnc to Hass tm2
    May 2010
    25
    for a couple days Im trying to DNC into a Haas TM2, have tried just about every setting on the mastercam side, we are using X4, we have set the Hass control to DNC and set the baud, bit, xonxoff same as computer but nothing is working, many times mastercam is sending but the Haas is getting nothing, did not find anywhere in the mastercan config to set weather I an sending full file of just drip but nothing is working for me, anyone doing this that can provide some helpfull advice
    thanks
    May 2004
    4519
    Can you send from the machine to the computer? Possible bad cable?
    May 2010
    13
    Did you check to see if you had the correct com port selected?
    Apr 2003
    3578
    what are you using for a cable are you by chance using a USB to Com port?
    Cadcam
    May 2010
    25
    believe we have the null cable, we can send to machine but it send the full program not drip, the machine does run but when the memory is full it errors the Haas, we are using a laptop thro a usb to serial cable, then null cable to the Haas, all settings on the computer match the Haas, we have tride changing several settings with no better sucess
    May 2010
    25
    one other thing, what feedback should one see on the Haas and mastercam when doing dnc, should the computer give some feedback other than finished sending, does the Hass do anything other than the screen full of code and running line by line same as when a program runns from memory
  1. hass SL-10
    By cncrookie93 in forum Haas Lathes
    Last Post: 03-06-2012, 07:07 PM
  2. hass d offsets
    By antny in forum OneCNC
    Last Post: 07-20-2009, 03:50 AM
  3. HASS SL20
    By MadMan5000 in forum DNC Problems and Solutions
    Last Post: 07-13-2009, 01:10 PM
  4. hass / mastercam newbie
    By yz426four in forum Haas Mills
    Last Post: 08-29-2008, 05:17 AM
  5. looking to buy USED HASS CNC mill
    By H_U_S_S_A_M in forum Want To Buy...Need help!
    Last Post: 04-23-2008, 10:46 PM
