Based on Tom's recommendation in this thread, I bought a Decko/Barracuda/Superior submersible pump to replace the OEM pump in my home-built larger coolant tank. I also took the opportunity to implement an idea that I got from reading about Don's nipple sleeve (I probably could have worded that better... ) in this thread -- a riser for the coolant line.
First, since the pump has 1-1/4" NPT output threads, I bored out a suitable pipe cap, and machined down a 1/2" close nipple which I glued in the cap.
I made the riser from 1/2" Code 40 pipe just because of the threaded end (which ultimately turned out not to be necessary). I machined out a 3/4" PVC coupler on one end for a tight fit on the nipple in the Tormach stand, and cut the stop out of a 1/2"-to-3/4" bushing so that the 1/2" pipe would slip through. I cut down the O.D. of a 1/2" threaded coupling to slip through the Tormach stand nipple.
A few 1/2" NPT/FPT to 1/2" hose barb fittings (underground sprinkler fittings) and two pieces of 1/2" I.D. flexible PVC tubing completed the installation.
A service loop of the flexible tubing accommodates the full Z movement (two of the below pictures are at the extremes) and there is no leakage path down through the stand pan.
I stabilized the riser with a 1/2"-to-1-1/4" bushing split in half and clamped onto the riser up against the bottom face of the pan with a hose clamp.
So far I'm really happy with both the pump and the riser. The pump is almost silent compared to the OEM pump and starts pumping quickly. I did reuse the check valve that I had installed on the OEM pump early in my Tormach's career.
Given the way that the bottom end of the riser turned out, and the fact that I already used a slip-to-threaded elbow at the top end, I could have made the riser from plain pipe and turned down a slip-to-threaded coupling at the bottom end. (I could not find a 1/2" FPT to 1/2" barb fitting after much searching, which would have eliminated the coupling entirely.)
Anyone need an OEM coolant tank and pump? I'll sell them for $40 plus shipping. The pump has my "pumps down to the last drop" riser on the inlet and works as well as an OEM pump ever did.
Randy
