586,494 active members*
2,401 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1991 VF1 Servo Motor Ohm Check
Results 1 to 6 of 6
    Apr 2004
    41
    Hello,
    Would like to Ohm out some DC brush motors on a 1991 VF1
    Does anyone know the specs? or the Wattage the motors are rated at.
    May 2012
    67
    Re: 1991 VF1 Servo Motor Ohm Check
    Speed,
    I recommend using a megger and checking the motor resistance leg to ground (disconnect from the amp first!). If it's under 1meg ohm then you have a problem.
    Thank you,
    Dec 2003
    24223
    One problem to watch when using a high voltage megger (550v/1kv) is that the megger can induce tracking on carbon traces.
    I tend to use a low voltage meter, or better still, if the motors have been in operation for some years, indicated by low brush length, I remove the end bell and clean them first.
    Typically DC brushed should not be left for more than two brushes replacements before reconditioning, minimum.
    Al.
    Albert E.
    May 2012
    67
    Al,
    That is very interesting, but I have not had any problems in the field. Have you seen any problems associated with this?
    Thank you,
    Feb 2010
    1184
    Al.
    +1
    Dec 2003
    24223
    Quote Originally Posted by Precision MT View Post
    Al,
    Thank you,
    Yes I have personally seen it happen, a small illuminated trace occurs through the carbon track, it most likely was there before to some degree, but the Megger only aggravates the situation, and burns the insulation if persisted.
    Al.
    Albert E.
  1. how do you check a motor
    By cob in forum Phase Converters
    Last Post: 06-24-2010, 04:34 AM
  2. Ground fault error light on 1991 Partner 1D servo amps
    By Jim Shaper in forum Milltronics
    Last Post: 03-10-2010, 01:35 AM
  3. 435 Runaway :Check motor wiring
    By electromech31 in forum Centroid CNC Control Products
    Last Post: 09-12-2009, 06:15 AM
  4. FANUC Servo ALPHA SERIES HOW TO CHECK
    By CNC SERVICE in forum Fanuc
    Last Post: 09-09-2007, 08:37 AM
  5. Check Carriage Sensor or VC Motor
    By jstovall in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-17-2006, 01:52 AM
