587,446 active members*
3,197 visitors online*
Thread: anilam 1100m
    Mar 2008
    12
    anilam 1100m
    hello
    I am potentially going to buy a lillian cnc vertical mill with anilam 1100m controller.
    I am currently used to programming in g codes and toolpathing programs in bobcad. I think that this controller is conversational?, not quite sure what that means?
    My questions are,
    1-Has anyone had experience with this controller and successfully
    programmed it with bobcad?
    2-Is the controller/machine truly 3d?
    many thanks
    paul
    Apr 2008
    49
    We have 3000m control and it only takes Conversational, meaning no G-Codes since it will not understand it. I use mastercam to generate the conversational using mastercam post.
    3D is possible since MasterCam will break 3D into vectors anyway.
    Mar 2011
    67
    Here's a little known secret...
    Both the 1100 and the 3300 can run G-code straight up, as long as every line begins with an @ sign.
    @N10 G70 G90
    @N20 G0 T0 Z0 M5
    etc..
    @N100 M02
    If you format a program like that, and you give it a .M extension, you can transfer it to the CNC and run it. Just can't easily re-edit it there. Download a 5000M or 6000M (G-code) manual from their website and that will answer most questions about what format the G-code address letters would have to be in for it to like it.
  1. Anilam 1100M passwords
    By edbanks in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2014, 10:48 PM
  2. Anilam 1100M pinouts
    By actionman in forum Controller & Computer Solutions
    Last Post: 03-05-2013, 12:53 AM
  3. Anilam 1100m software
    By BenSteigerwald in forum Controller & Computer Solutions
    Last Post: 04-01-2012, 09:38 PM
  4. Converting Anilam 1100m to mach 3
    By BillsBoatRepair in forum Mach Mill
    Last Post: 07-23-2009, 03:36 AM
  5. Supermax YCM-30 with Anilam 1100M controls
    By edbanks in forum Uncategorised MetalWorking Machines
    Last Post: 04-14-2009, 09:21 PM
