587,768 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Shaft and ball screw nut - mounting method
    Jun 2007
    12
    Hi.
    I'm looking to attach 1605 ball screw nut to one end of 40mm hollow shaft (22mm). (http://serwer1340157.home.pl/max911/print/ShaftNut.jpg)
    I was thinking on welding a flange and bore the inside of the shaft. I do not have any metalworking experience and would appreciate all advice.
    Thank you.
    Maciej
    Dec 2013
    5716
    Re: Shaft and ball screw nut - mounting method
    What you propose seems reasonable. With no metalworking experience you might want to find a local machine shop or home shop hobbyist that can do this for you. It really requires a lathe to get it right. Maybe post in the RFQ forum.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2007
    12
    Yes. I will definitely do it but was not really sure what to ask for
    Dec 2013
    5716
    Just describe what you want as you did above, and attach the drawing of what you want. Also give your location, maybe somebody local will pick up on it.
    Jim Dawson
    Sandy, Oregon, USA
  1. ball screw mounting plate thickness
    By jschoch in forum Linear and Rotary Motion
    Last Post: 06-23-2018, 07:02 PM
  2. Flexible coupling for 4.5 mm ball screw shaft
    By Avitus in forum Linear and Rotary Motion
    Last Post: 07-22-2016, 07:40 PM
  3. Replies: 4
    Last Post: 09-18-2013, 04:38 AM
  4. Installing mounting blocks on ball screw
    By dsalihi2 in forum DIY CNC Router Table Machines
    Last Post: 06-09-2012, 12:21 AM
  5. Ball Screw Mounting Question.
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2005, 07:02 PM
