I would like to take a 1.25"diameter rod and cut a ball on the end. The shaft would need to be turned down to .25". I can do the drawing fine but I run into a problem or 2 in real world execution. Is there a way I can do this with 1 cutting tool (not a form tool)? If I do have to use a combination of a left hand and a right hand tool, how do I index/locate the tool at the change? I am doing this on a Sherline so depths of cut have to be small and directed towards the chuck. I would also think it would be best to do most of the cutting with the tailstock in place and then maybe a finish pass or 2 to clean up after moving it out of the way. Or what procedure might you use to accomplish this on a lathe (not referring to a ball turner). Thanks
It's doable with one tool which is a grooving tool. Although i simulated it on a difference cad/cam to BC, the name of which i will not mention here as it's not appropriate.
Obviously this is a plunging profile so tool towards the centreline.
With more than one tool and no QC toolpost it would be difficult and is a separate question.
I just had a part to cut that I could not use a conventional (diamond/square/triangular insert on.
I ended up loading tool 19 in the Rough portion of the code and changed the tools measurements as follows
0 radius
.061 tool width.
then I just used a .061 HSS cutoff blade as my tool. A tool this thin lacked rigidity and had to be relieved a bit on each side to allow slight side cutting. Still it would go down into .100 wide grooves that were .81 deep and would cut all my other geometry.
I could not find an insert tool that I had that would cut all the features on this part.
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
