587,331 active members*
3,278 visitors online*
    Apr 2005
    13
    2 steppers on same axis
    Hi
    I am very new here and I am building a Plasma table that I also want to double for wood. I have tried to search on finding out how to have 2 steppers control one axis. For the x axis I want to have one servo on each side of the machine. Is it poissible to set the servos to run in parallel ? I was also thinking one servo and a belt drive for both sides. Please let me know the best way to do this.
    Joe
    Nov 2004
    65
    have the 2 x axis steppers totaly seperate as far as the mechanics go , and set up the 2nd x asis as a slave of the first in software , for example Mach2
    or drive both axis from the same signal , but you then have to be careful that they sync together , alternativley belt drive or use a fixed gear train between both sides so they stay in step and track together
    Apr 2005
    13
    I have not yet explored the software so I was unaware of that option. I just wanted to know so I can get the table built correctly.
    Joe
    Like da21 said, Mach2/3 has a slaving option for that purpose. If using other control software, a lot of people use the step and direction signals for 1 axis, but send them to 2 drives.
    Here's a nice setup with one motor and 2 belt driven screws. http://website.lineone.net/~rmtucker/
    Aug 2004
    2849
    CanopyFX.....okay.....why do you wish to have 2 of each...steppers and servos...just wondering??
    Apr 2005
    13
    Quote Originally Posted by ViperTX
    I got carried away and used servo when I ment to say stepper.
    Joe
  1. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  3. No Encoder Counts On X Axis. Y=OK
    By murphy625 in forum CamSoft Products
    Last Post: 03-09-2005, 03:20 AM
  4. 2 axis to 3 axis conversion
    By drembedded in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2004, 05:32 PM
  5. My Lathe project; might CNC it one day
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2004, 02:27 AM
