587,119 active members*
3,536 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Input requested: Bridgeport CNC Series 1 Servo - Retrofit
Results 1 to 7 of 7
    Mar 2010
    29
    I recently acquired a Bridgeport CNC Series 1 Servo machine that at some point had been converted from Boss controls to Fagor (model 800M) back in the day. The spindle had also been converted to run on a VFD on 110v. The machine runs in all axis currently, but the Fagor control is a very old control that doesn't run on G code. As such, I am looking to do a retrofit to a Mach 3 based system.
    I have used Mach 3 on 3 other machines in the past but they have been stepper based machines and much smaller (read as desktop machines).
    Anyway, after a lot of research, I am thinking about a conversion setup that looks like the following:
    CNC4PC Ethernet SmoothStepper
    CNC4PC C32 BOB
    CNC4PC C34DG (if using DG4S driver)
    DG4S-016035 Servo Drivers (or maybe a Viper)
    Continue to use the existing VFD for the spindle
    Continue to use the existing eStop and limit switches
    I will also need to add a 5 and 12v power supply. I am thinking that I can use the current power supply for the motors but will have to see about that. All of the rest of the existing cabling and controls would be removed. The new components would be loaded into the existing rear housing.
    I will also use the existing Servos which are Servo Dynamics MTS30M-38 no. S23706 with an rpm of 1400 and a volt of 47 from SEM.
    Your thoughts and input would be greatly appreciated before I plunk down cold hard cash on this retrofit.
    Oct 2010
    1189
    Re: Input requested: Bridgeport CNC Series 1 Servo - Retrofit
    Hi ,
    i am just about to Finnish a bridgeport 412 I retrofit. To save costs we did (so far ) leave the original servos in
    Yesterday tha act worked first time
    Bridgeport 412 interact atc initialize - YouTube
    i was just too afraid for the ram (and it was good because the mechanic did mount the Z Axis magnet wrong ,.. (to deep )
    And here some cycles Bridgeport 412 interact atc linuxcnc test - YouTube
    so maybe i can help with infos
    thomas
    Mar 2010
    29
    just an update. The mentioned the wrong specs for the servos above. They are 140V/ 47A servos and a max RPM of 3700. I am assuming at this point that they have encoders as the boss system was removed and replace with a FAGOR 800M controller system at some point in the 80/90's.
    I purchased the following items from Arturo. I need to find some time to start working on it.
    1. Ethernet Smooth Stepper
    2. C32 Dual Port MultiFunction Board
    3. C48 eStop connector Board
    4. 3- DG4S-16035 servo drives
    5. C55 Dual 25 amp Relay Board
    6. C34DG Driver to RJ45 Connector board for Dugong drivers
    7. 5v power supply
    8. 12v power supply
    9. USB programming stick
    Any thoughts on creating a mounting board for the new components out of wood that I can setup and and trace all of the new wires on and then install into the old back cabinet of the series one after it is cleaned out? issues?
    Also, what is the best way to determine if my servos indeed have encoders on them? Trying to figure out if I need to purchase encoders or if I can use the what might already be there.
    I look forward to any help that the forum can shed on my questions. Thanks.
    15362
    bhouin
    You should look at Dmm for your Servo Motors/Drives, what you are looking at don't compare, cost is much the same, CNC4PC sell the Dmm servo Drives Motors as well
    DMM | Multi-Axis Solutions
    Mactec54
    Oct 2010
    1189
    Which servos do you have at the machine Sem ?
    Mar 2010
    29
    Yes, they are SEM.
    Oct 2010
    1189
    If you like i have Documented our Journey a Little http://www.tkamsker.at:8080/web/pub/analyse
    And if you Look at Umsetzung you See exactely where i have taken which Route maybe some ideas for you ,..
  1. Bridgeport cnc series 1 retrofit
    By hscess in forum Want To Buy...Need help!
    Last Post: 04-05-2013, 02:59 AM
  2. Another Series 1 Bridgeport Retrofit
    By deanq in forum Vertical Mill, Lathe Project Log
    Last Post: 08-21-2012, 10:40 PM
  3. Bridgeport Series 1 MK 2 retrofit
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 09-30-2008, 07:04 PM
  4. Bridgeport Series II un-retrofit.
    By Buddy0228 in forum Bridgeport / Hardinge Mills
    Last Post: 05-01-2008, 08:39 PM
  5. Bridgeport Series II Retrofit
    By Cold Fusion in forum Vertical Mill, Lathe Project Log
    Last Post: 07-01-2007, 02:37 AM
