587,529 active members*
3,353 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Surfacing 7075 plate, recommendations?
    Jun 2019
    Hello there!
    Wondering if someone could give me some guidance. I'm designing two parts for a CNC router which I'm planning to get machined, I haven't chosen a manufacturer yet.
    They measure
    400mm x 217.5mm x 25-30mm
    250mm x 265 x 25-30mm
    In anyone's opinion, would a surfacing cut of 0.5mm cause any distortion in those plate sizes? How light a cut could I get done while still giving a consistent finish on stock 7075 plate?
    Cheers
    15362
    Re: Surfacing 7075 plate, recommendations?
    Quote Originally Posted by JustinP1 View Post
    Hello there!
    They measure
    Cheers
    It would depend on the material you use, 7075 can be processed in different ways cast is best for plates which gives you less distortion for machining a plate like this, it should be Blanchard Ground, or double disc Ground, you could just buy it already Ground also
    If you want it better than .005" then you would mount it to your machine base if it is not the moving part, and then have it surfaced
    Mactec54
    Jun 2019
    Thanks Mactec54,
    Cast ground 7075 plate might be the way to go
    15362
    Thanks Mactec54,
    That is what most use, also known as cast tooling plate, there are companies that will grind the plate also
    Mactec54
